LatinLover
Anmeldungsdatum: 26.08.2002 Beiträge: 48
Beitrag 80 - Verfasst am: Fr Okt 24, 2003 9:22 Titel: |
Habe es hinbekommen
Man muss nur bei Optionen einge Sachen einstellen und wenn man dann auf Video erstellen geht noch mal ein paar Sachen einstellung!
Das Programm ist wirklich selbst erklärend.  |
Beitrag 81 - Verfasst am: Fr Okt 24, 2003 9:57 Titel: |
Na sehen Sie! _________________ Gier und Uneinsichtigkeit fressen den Verstand! |
Beitrag 82 - Verfasst am: Fr März 26, 2004 14:30 Titel: |
ProShow Gold v2.0.1524
ProShow lets you create amazing slide shows that play on your PC or
TV. Just drop in your photos and sound tracks, pick your transitions
and timing and go!
Create slide shows for any occasion!Use ProShow to easily create
stunning slide shows for friends, family, business, or just for fun!
Just select your photos and drop them in the show. Add a custom sound
track or pick from over 170 stunning transition effects to add that
final touch.
Take your photos further!ProShow gives you more output options than
any other slide show software.
Create video CDs that play back on your TV.
Generate MPEG video files for PC viewing. Build screen savers for
yourself or others. Make self-contained executable slide shows (EXEs),
perfect for e-mailing or posting online. Write PC autorun CDs that
automatically play when inserted into a PC. ProShow does it all!
More info:
http://www.photodex.com/products/proshowgold
Zitat: | New In ProShow Gold 2.0
March 24, 2004
Create DVDs with ProShow Gold
Fully integrated DVD authoring - no additional software necessary
ProShow Gold handles everything, from video encoding to disc burning
Unmatched DVD video quality
Add multiple shows to a DVD, and include a PC autorun EXE
Support for a variety of DVD formats - HQ, LP, SP, and more
Supports NTSC and PAL
Supports both widescreen (16:9) and fullscreen (4:3) shows
Publish Streaming Slideshows on Your Website
Create streaming web shows you can post on your own site
Requires no server software or configurations
Provides perfect quality playback from within any webpage
Highly configurable, including options for scaling, protection and more
Online Show Sharing at Photodex.com
Publish your show online at Photodex.com
Fully integrated with ProShow Gold 2.0
Free show sharing for registered users
Add Caption Effects
Over 70 high quality caption effects
Apply effects to any caption or global show caption
Control effects for fly-in, fly-out, and normal behavior
Slide Motion ('Ken Burns') Effects
Bring shows to life with slide motion
Pan, zoom and rotate slides
Combine panning, zooming and rotation on the same slide
Intuitive, real-time, 'before-and-after' interface for configuration
Easily move from one slide to the next with motion matching
Add Video to Slides
Use a video clip in any slide
Add motion effects to video - pan, zoom and rotate video real-time
Overlay captions and apply transitions to video clips
Apply all the same effects to video that are available for images, including color correction, scaling and more
Easily crop video to just the desired segment with starting and stopping offsets
Improved Executable and Screensaver Creation
Create smaller executables with automatic audio compression
Improved font support in EXEs now allow any font to be used
All New DVD / CD Writing Engine
Improved DVD-R/RW, DVD+R/RW, and CD-R/RW drive support
Additional drive support can now be added on-demand when available
New DVD / CD writing engine removes issues reported with previous versions
More Transition Effects
Now over 280 transition effects
Easily access recently used transition effects
All new 'soft-edge' transitions
Redesigned transition selection window
All New Display Engine
Higher performance and smoother display
More responsive real-time preview
Improved Interface
All new slide customization interface
Improved show output dialogs
Improved Video Encoding
Higher quality video output
Uses Lanczos scaling to maximize image quality
High speed video rendering |
_________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Chavez
Anmeldungsdatum: 15.12.2001 Beiträge: 137 Wohnort: Frankfurt am Main
Beitrag 83 - Verfasst am: Mi Jun 09, 2004 7:28 Titel: |
Benutzt von euch noch wer das Proggi?
Ich versuche seid 4 Tagen eine FotoDVD aus 1200 Fotos verteilt auf 14 EinzelShows zu erstellen. Entweder stürzt das Proggi ab, oder er Produziert eine DVD die in meinem Stehallein nicht funktioniert (Nicht mal am PC ). Hat das schon mal wer hinbekommen?
Wenn ja wie ?
Gruß Matthias _________________ Erst kurz im Forum und schon alles durcheinandergebracht ;) |
BongoBong
Anmeldungsdatum: 22.07.2003 Beiträge: 203
Beitrag 84 - Verfasst am: Mi Jun 09, 2004 7:57 Titel: |
Hallo Chavez
wir diskutieren an einer anderen Stelle weiter:
http://www.dvd-svcd-forum.de/forum/viewtopic.php?t=18533&highlight=
Eine Einzelshow mit ca. 600 Bildern hatte ich auch schon mal, das Programm ist aber nur wärend der Arbeit passiert.
Seit ich jetzt regelmäßig abspeicher ist es mir nicht mehr abgestürzt.
Es gibt übrigens seit Vorgestern ein Update, vielleicht hilft dir das schon mal weiter.
Dirk |
Beitrag 85 - Verfasst am: Do Jun 24, 2004 1:59 Titel: |
ProshowGold1561-24-6-04
B.T.W.
Hab ich folgendes gemacht:
MPG-2 mit hoher Datenrate (8000) in ProshowGold erstellt. Den mit ProCoder in ein DV-AVI (Canopus Codec) gerendert. Diesen AVI in Premiere mit in einen Film "eingebaut". Rausgerendert - mit ProCoder weiter bearbeitet usw. Wurde ned schlecht. Das zum einen.
Aaaber - was mit aufgefallen ist: Das ProshowGold macht grundsätzlich wohl InterlaceMPGs und auch noch CBR. Kann man auch nirgends ändern, gibt sich keine Einstellmöglichkeit. Dumm so was Wir haben doch Vollbilder ! - Wäre progressiv doch besser.
Also ...nur mal Just-for-Fun, hab isch den DV-AVI nochmals im ProCoder zum einem non-interlace (progressiv) MPG verwurstelt. Wird auch sofort um die Hälfte kleiner als der ProshowGold-InterlaceMPG.
Gut ... ein Problem ist Motion&Effekts bzw Panning, also immer wenn Bewegung ins Spiel kommt. Dann kann es flimmern. Reine Standbilder jedoch kommen m.E. sauberer auf TV rüber.
Kann das jemand nachvollziehen ?
Man müsste im Proshow einfach auch einen AVI rendern können. Noch geiler - einen Frameserver AVIsynt einbinden können. Dann könnte man direkt an einen externen Encoder gehen ! *wunschTraum*
Ob man das mal an Herrn Proshow rantragen sollte
Sooo ... nochmal:
- Mit ProShow die Bildershow machen
- MPG-2 File encodieren lassen (volle Pulle)
- Mit ProCoder in DV-AVI (CanpusCodec) rendern
- DV-AVI kann in Premiere (oder sonst was) vertont, bearbeitet werden
- oder
- DV-AVI mit ProCoder(Express) in ein ordentlichen MPG(VBR) enocdiert werden
- Mit einem vernüftigen (!) DVD-Authorprogi als DVD (miniDVD) authoren
Das kommt gut ... - und die Files werden vieeeeel kleiner bei gleicher Qualität [ca. 50%]  _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
BongoBong
Beitrag 86 - Verfasst am: Fr Jun 25, 2004 11:20 Titel: |
Hallo Helmut
Danke für den Update-TIpp
Bei deinem Problem mit dem Interlacing kann ich leider nicht wirklich weiterhelfen, da ich mich darin nicht gut genug auskennen. Ich komme aber gerade aus dem Doom9 Forum und habe dort dazu einen Thread verfolgt. Dort wird erklärt, daß das deinterlacing garnicht so gut sein soll, wenn man das Video sowieso wieder auf einem Fernseher anschaut, weil der die Bilder interlaced darstellt. Die Halbierung der Datenmenge kommt wohl daher, daß beim deinterlacing die fehlenden Zeilen interpoliert werden und deshalb das Bild eigentlich aus zwei gleichen Halbbildern besteht und damit die Datenmenge nur noch halb so groß ist. Wenn das Video allerdings interlaced bleibt hat man zwei unterschiedliche Halbbilder mit der vollen Information zum Bild. Ich offe ich hab mich unklar genug ausgedrückt. Ganz verstanden hab ich es nicht, es erscheint mir aber soweit logisch. Schau dir doch mal den Thread an, der User Scharfis Brain hat scheinbar sehr viel Erfahrung mit dem Interlacing.
http://forum.gleitz.info/showthread.php?t=13186
Deinen Workflow kann ich aber nicht ganz verstehen. Du erstellst ein Video mit verfälschender Kompression (MPEG2 mit 8000 k, ich würde mind. 9000 nehmen), dann wandelst du es in ein unkomprimiertes Format um es dann erneut zu komprimieren.
Das kann doch nicht besser sein als das Ausgangsmaterial! Ich hatte es auch schon mal gemacht, daß ich eine Diashow und zwei Filme zusammen bringen wollte. Ich hab dazu aber noch ein Alternativprogramm zum Diashow erstellen. Ich nutze dazu den SlideShowMovieMaker http://www.joern-thiemann.de/subpage/index.htm?/tools/ssmm/index.htm. Mit ihm kann ich die fertige Show in jedem AVI-Format ausgeben, von dem ein Codec installiert ist. So hättest du dann wenigstens eine Komprimierung weniger.
Dirk |
Chavez
Beitrag 87 - Verfasst am: Fr Jun 25, 2004 11:28 Titel: |
Helmut hat folgendes geschrieben: | ProshowGold1561-24-6-04
- oder
Du mußt ja Datenmengen haben
Wieso du die DiaShow Filmchen in Premiere nochmals bearbeitest, entzieht sich meinem Verständniss
//EDIT
Ah sehe gerade, du vertonst deine Filmchen in Premiere, das scheint einfacher zu sein, als in PSG. Das ganze ist aber auch in PSG zu schaffen.
//EDIT ENDE
Chavez
PS.: OK bei 1200 Fotos (14 Shows + Intro Extro) war bei mir ein DVD Rohling bis zum letzen MB voll (MPGS mit PSG und Authoring mit DVD Lab). _________________ Erst kurz im Forum und schon alles durcheinandergebracht ;) |
Beitrag 88 - Verfasst am: Fr Jun 25, 2004 12:17 Titel: |
@ BongoBong
Mit interlace oder non-interlace kenne ich mich aus - glaubs mir.
Also .. wir haben als Vorlage "Vollbilder" ! Keine Interlacefilme wie von Kamera geliefert. Kannst also als progressiv verarbeiten. Aber - wenn Bewegung ins Spiel kommt, dann wird es eben problematisch. An dem Punkt halt wo man Bilder animiert, Pannig usw. Ist also eher nicht so geeignet.
Das ist ein Spezialfall - der sich aus meinem Workflow ergibt. Ich baue die DiaShow in einen Film mit ein. Ansonsten - wenn es um reine DiaShow geht, besteht kein triftiger Grund nochmal mit einem Schnittprogramm zu arbeiten.
Du erstellst ein Video mit verfälschender Kompression (MPEG2 mit 8000 k, ich würde mind. 9000 nehmen), dann wandelst du es in ein unkomprimiertes Format um es dann erneut zu komprimieren. Das kann doch nicht besser sein als das Ausgangsmaterial
9000 geht ned. Davon ab: Das ProShow macht CBR - Original encodiert in ProShow z.B. 890 MB, - mit ProCoder (auch interlace) auf 5000 VBR reencodiert (weil ich es in dem Falle auf miniDVD authoren will) nur noch die Hälfte. Wenn ich gleich in ProShow auf 5000 CBR gehe, ist das Ergebnis wesentlich schlechter (qualitativ) und der File größer.
Deshalb sag ich ja: Entweder das ProShow böte mehr an Encodereinstelloptionen - oder eine Schnittstelle zu ext. Encodern (Frameserver) - oder man muß halt so einen "Umweg" gehen. Kannst auch das MPG direkt reencodieren. Das ich über AVI gehe - hatte den o.a. Sinn. (Einbauen in ein Film-Schnittprojekt) ... _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
BongoBong
Beitrag 89 - Verfasst am: Fr Jun 25, 2004 13:15 Titel: |
Hallo Helmut
Ich hab ja geschrieben, daß ich mich nicht so auskenne
Abgesehen davon glaub ich dir mal garnix , aber du hast mir bewiesen, daß du dich auskennst.
Du hast vollkommen Recht, wir gehen ja von Vollbildern aus und machen erst Interlaced-Material daraus.
Bis jetzt hatte ich nur Show mit der besten Qualität erstellt, ich werd mal austesten wie sie aussieht, wenn ich stärker komprimieren muß.
Die letzte Show die ich erstellt hatte ging gerade so auf eine DVD ich musste sogar kürzen um nicht zu Groß zu werden.
Es wäre also wirklich sinnvoll von Photodex entweder eine variable Datenrate oder die Ausgabe in AVI zuzulassen.
Mal schauen was die sich noch einfallen lassen.
Dirk |
Beitrag 90 - Verfasst am: Fr Jun 25, 2004 13:25 Titel: |
Die Sache ist ganz einfach:
Wir haben statische, unbewegte Vollbilder in guter Qualität als Vorlage.
Mit dem Vorlagematerial muß man mit Datenraten um 5000 VBR zu absolut guten Ergebnissen kommen. Kann man beweisen und nachvollziehen wenn man die Bilder ganz einfach in einem Schnittprogi zusammenklebt und mit einem "guten" Encoder wie ProCoder encodieren läßt. Bekommst saugute Qualität bei wesentlich kleinerer Filegröße als wenn du das ganze mit dem ProShow und dem dort integrierten Encoder bei 8000 CBR machst.
Der Haken liegt also beim ProShowEncoder ...  _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
BongoBong
Beitrag 92 - Verfasst am: Di Jun 29, 2004 15:48 Titel: |
Hmmm ... geradezu beängstigend, diese dauerenden Updates
Finde aber keinen ChangeLog ? Was ist neu ? Was gefixt ?  _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
BongoBong
Beitrag 93 - Verfasst am: Mi Jun 30, 2004 8:38 Titel: |
Meine ChangLogsuche bei Photodex hab ich mittlerweile aufgegeben.
Beängstigend finde ich die Update-Strategie von denen eigentlich nicht.
Die gehören wenigstens noch zu den Softwareherstellern, die sich um ihre Software kümmern und versuchen dem User eine fehlerfreie Software zur Verfügung zu stellen.
Da wird man von größeren Herstellern, wie z.B. Ulead eher mal im Regen stehen gelassen.
Ich finde es gut, weiter so Photodex
Dirk |
Beitrag 94 - Verfasst am: Mo Dez 20, 2004 1:39 Titel: |
ProShow Gold
Version 2.0 Upgrade
For Windows XP, 2000, Me, 98 and 95
Version 2.0.1591 - November 29, 2004 _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Beitrag 95 - Verfasst am: Mo Dez 20, 2004 1:52 Titel: |
was kann es jetzt? _________________ Sotiris
Beitrag 96 - Verfasst am: Mo Dez 20, 2004 1:56 Titel: |
Es kann sich von Version 2.0.1563 auf Version 2.0.1591 updaten
Fertisch ... mehr weiß ich auch ned. _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Beitrag 97 - Verfasst am: Mo Dez 20, 2004 1:59 Titel: |
Geeeeeeeeeeeeiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiilllllllllllllllllllllllllllll _________________ Sotiris
Beitrag 98 - Verfasst am: Mo Dez 20, 2004 2:19 Titel: |
Zitat: | Changes in the Current Revision of ProShow Gold 2.0
November 29, 2004 - Version 2.0.1591
Fixed problem with captions not appearing correctly when captions are set below transition effect.
Fixed problem with stall / lockup during video rendering.
Changes in Previous Revisions of ProShow Gold 2.0
November 23, 2004 - Version 2.0.1589
Fixed crash problem with captions below transitions
Fixed problem with "captions below transitions" on blank slides
Player now maximizes to correct monitor on multi monitor machines
Fixed problem with record slide timings stopping after about 16 minutes.
Changed buffering logic at start of show to improve problems with stuttering at startup.
Shows which haven't been saved no longer default to the same filename as the last saved show
Mouse button down events on the slide list now halt preview playback
Option to loop web show is no longer improperly grayed out
Changing the DVD output quality now properly recalculates the size of the show
Fixed problem where record slide timings wouldn't work if started from the middle of the show
Fixed problem with audio not fading if fade time is longer then slide duration
September 26, 2004 - Version 2.0.1583
Audio now loops in EXE menus
Fixed problem with some AVIs being detected as JPGs
Fixed problems with importing some video files
Fixed audio fading problems
Fixed problems with stills / video options not appearing on VCD menus when both still and video shows are included
Fixed problem where still VCD shows only contain first audio file. Subsequent audio files do not play.
Fixed problems with (S)VCD still shows
Fixed problem with show backgrounds going to black during transitions
EXEs and Web show snow hide mouse cursor during playback
Fixed problem with screensavers not looping
Added new overstate effects to EXE and Web show menus
Fixed problem with protection window appearing behind web browser for Web shows with protection enabled
Improved buffering for video in slides
Fixed problems with video outlines / shadows being wrong
Fixed crash problem with record slide timings feature
Fixed problem with record slide timings only playing first track of the soundtrack
Added option in captions list to have caption occur above or below transition effect
Prevented blank slides from becoming the show thumbnail, unless the user specifically set it.
July 27, 2004 - Version 2.0.1571 - Improved SVCD/VCD compatiblity
- Fixed several reported stability issues.
July 12, 2004 - Version 2.0.1568 - Fixed several reported stability issues.
July 8, 2004 - Version 2.0.1567 - Fixed several reported stability issues.
July 5, 2004 - Version 2.0.1566 - Fixed several reported stability issues.
July 1, 2004 - Version 2.0.1565 - Fixed problem with background image not displaying properly during some transition effects
June 29, 2004 - Version 2.0.1564 - Fixed several reported stability issues.
June 28, 2004 - Version 2.0.1563 - Fixed several reported stability issues.
June 24, 2004 - Version 2.0.1562 - Fixed 3 reported stability issues.
June 22, 2004 - Version 2.0.1561 - Fixed 12 reported stability issues.
June 17, 2004 - Version 2.0.1560 - Fixed 4 reported stability issues.
June 16, 2004 - Version 2.0.1559 - Fixed 10 reported stability issues.
June 11, 2004 - Version 2.0.1558 - Fixed 6 reported stability issues.
June 10, 2004 - Version 2.0.1557 - Fixed 15 reported stability issues.
June 9, 2004 - Version 2.0.1556 - Fixed 15 reported stability issues.
June 8, 2004 - Version 2.0.1555 - Fixed 48 reported stability issues.
Added improved feedback of stability problems
Fixed assorted stability problems
Fixed problems with captions popping on 16:9 shows
Fixed aspect ratio problems with mixing menus with 16:9 and 4:3 shows
Fixed problems with Loop All / Play All not working on EXEs
Fixed problems with Slide Options dialog sometimes appearing off-screen
Fixed problem with soundtrack disappearing after reloading a show
Fixed crash problem with AMD K6-2 based systems
Fixed various stability issues
Numerous stability issues corrected and improved
Improved DVD/CD burning support
Added progress indicator when files are dropped into a show
Improved video encoding speed on dual processor and hyper-threaded machines
Improved image quality on DVD and PC playback when image is scaled
Fixed problem with DVD-R writing not working properly
Fixed crash problem when choosing DVD, VCD or PC Autorun output option
Fixed problem with custom background options not working properly on blank slides
Fixed problem with disc burning stalling before complete on some machines
Fixed problems with panning across panoramic images
Fixed problem with PAL video being encoded at incorrect framerate
Fixed problems with DVD output - now 100% compliant
Fixed problems with show sharing and certain firewalls
Fixed problems with menus on EXEs
Fixed installation error on Windows Me/98/95
Fixed problems with using video in slides
Fixed problems with PCM audio for DVDs not working correctly
Fixed problems with screensavers containing menus
Fixed several issues with slide sounds, sound fading, and offsets
Fixed alignment issues with outlines on images
Fixed issues with VCDs not working on some DVD players |
_________________ Grüße
