thetrumpet65
Anmeldungsdatum: 22.01.2002 Beiträge: 104 Wohnort: bayern
Beitrag 0 - Verfasst am: Di Sep 24, 2002 18:32 Titel: |
hi! wenn ich eine mpeg2-datei in tmpgenc - merge/cut lade und dann den film mit doppelkick anklicke, damit ich sehe, wo ich schneiden muß, kommt folgende fehlermeldung:
could not open this file with direct show (0x80040154)
detail:!s!3/41E!G!! |
thetrumpet65
Beitrag 1 - Verfasst am: Mi Sep 25, 2002 14:18 Titel: |
niemand eine idee oder hilfe, was das sein könnte? |
Beitrag 2 - Verfasst am: Mi Sep 25, 2002 15:19 Titel: |
Siehe das bei www.tmpgenc.net
Zitat: |
* Note for Specification Change in TMPGEnc 2.57
[] When opening MPEG file with TMPGEnc
Because current version of TMPGEnc does not have own MPEG-2 decoder feature, it relies on other MPEG-2 decoders installed onto Windows system through Microsoft DirectShow to read MPEG-2 file.
Although Microsoft DirectShow does not support playbacking MPEG-2 file as default, by installing software DVD player etc., it is possible to playback MPEG-2 file. Microsoft Although DirectShow has such structure that additional component of DirectShow extends capabilities to read/playback other formats, however this is totally depending on software installed in your system, and it may be sometime unstable because of compatibility or conflict between such additional components, thus, we are not officially support/warrant the feature to read movie file Microsoft DirectShow.
The meaning of movie file is, AVI(Type1 DV format), .mpg(MPEG-1/2) .asf .wmv .mov in this case.
Although there are so many MPEG-2 decoder which can be installed onto Microsoft DirectShow. Not all of them can be worked for TMPGEnc. There are several decoder which is;
- not stable, as a result TMPGEnc looks like unstable in previous version.
- not allow other application to use the module, as a result, TMPGEnc can not read movie file.
TMPGEnc 2.57 reads MPEG-2 files only with specific official commercial legal MPEG-2 decoders made by CyberLink, Ligos and, Sony so that TMPGEnc reads MPEG-2 files most appropriate way by operating these decoders directly from TMPGEnc.
In this way, it improves the stabilities to read files, but only if one of these 3 decoders installed in your system. Other decoders can not be controlled by TMPGEnc.
There are at least 2 type of bitrate allocation, one is CBR, the other is VBR, however, Microsoft DirectShow is able to seek MPEG file encoded in CBR only, thus TMPGEnc can not do "Cut editing" which need accurate seek of file if the MPEG file is VBR. For example, if the file was encoded in VBR, audit or video may be stopped for a while at the point you cut.
If Microsoft Windows Media Player can not seek a movie, TMPGEnc can not seek the movie as well.
* Sony MPEG-2 decoder may be preinstalled VAIO RX models etc.
* There may be the case that an MPEG-2 file which can not be played through Microsoft DirectShow because of the decoder's specification despite you installed a software DVD player.
_________________ Gruß SVCDFan |
thetrumpet65
Beitrag 3 - Verfasst am: Mi Sep 25, 2002 17:36 Titel: |
hi svcdfan! mit meinem englisch ist es nicht so weit her, kannst du mir vielleicht in kurzen schritten sage, wo der hund begraben ist und wie ich den fehler beheben kann?
gruß, thetrumpet |
Beitrag 4 - Verfasst am: Mi Sep 25, 2002 19:22 Titel: |
@thetrumpet65
Kurz gesagt, Dir fehlen die DirectShow Filter für mpeg2 !
Installier einfach einen Software DVD-Player (oder installier ihn nochmal) ! Das sollte das Problem beheben !
thetrumpet65
Beitrag 5 - Verfasst am: Do Sep 26, 2002 17:23 Titel: |
@ BirdOfPrey!! ich habe powerdvd gelöscht und wieder installiert und tmpgenc futzt wieder, juhu.
ich danke dir
gruß, thetrumpet |
