Marcus Else
Anmeldungsdatum: 12.07.2001 Beiträge: 159 Wohnort: Braunschweig
Beitrag 0 - Verfasst am: Fr Feb 15, 2002 14:45 Titel: |
http://www.tmpgenc.net/e_download.html
Version : 2.52. 2002/02/15
Optimized for Pentium 3 / Athlon
Improved loading audio with DirectShow Multimedia Reader
Improved compatibilities, some AVI file were not able to be read.
Fixed bug : it was not able to recognize the length of AVI2(OpenDML)file.
At max number of frame of GOP, TMPGEnc now take the following into consideration.
"3:2 pulldown when playing", "Opposite 3:2 pulldown"
Improved framerate display at MPEG setting dialog when "3:2 pulldown"is chosen.
At Merge(Cut) of MPEG tools, if there is any error, it shows the detail of the error.
If an MPEG-2 file is selected at Project Wizard, it obtains field order info from the header of the file.
Viele Grüße
von
Marcus |
Ghola
Anmeldungsdatum: 01.01.2002 Beiträge: 13
Beitrag 1 - Verfasst am: Fr Feb 15, 2002 17:42 Titel: |
Hi
Was bringt die Plus Version noch für Vorteile ?
Schnelle Encoden ?
Besseres Bild als die Freie Version ?
Weil bis jetzt nur Höhere Auflösung !
Cu Ghola |
Beitrag 2 - Verfasst am: Fr Feb 15, 2002 18:34 Titel: |
NEU : TMPGEnc Version : 2.52. 2002/02/15
Unter einer neuen Domain mit der URL: http://www.tmpgenc.net liegt bereits die neue Version von TMPGEnc
http://www.tmpgenc.net/e_download.html TMPG D o w n l o a d s e i t e direkt
- Optimized for Pentium 3 / Athlon
- Improved loading audio with DirectShow Multimedia Reader
- TMPGEnc now judges field order automatically when a source is selected.
- Improved compatibilities, some AVI file were not able to be read.
- Fixed bug : it was not able to recognize the length of AVI2(OpenDML)file.
- At max number of frame of GOP, TMPGEnc now take the following into consideration.
- Improved framerate display at MPEG setting dialog when "3:2 pulldown"is chosen.
- At Merge(Cut) of MPEG tools, if there is any error, it shows the detail of the error.
- If an MPEG-2 file is selected at Project Wizard, it obtains field order info from the header of the file.
The following is only available in "TMPGEnc Plus".
Bug fix : the bitrate was too low at "2 pass VBR" with "Low resolution" setting.
Added 45 min / 55 min SVCD format to Project Wizard.
Added 85min / 110 min SVCD (out of standard) to Project Wizard.
und hier auch die TMPGEnc-2.52.34.129-Plus:
[url=http://210.150.5.219/files/TMPGEnc-2.52.34.129-Plus-EN.exe" target='_blank'>http://210.150.5.219/files/TMPGEnc-2.52.34.129-Plus-EN.exe</a>
Quelle:
<a href="http://www.pegasys-inc.com/e_download.html]http://www.pegasys-inc.com/e_download.html[/url]
The following is also recommended
- Larger than 1152 x 864 24bits color or higher
- CPU with MMX (e.g. Pentium III)
- CPU supporting streaming SIMD Extensions (e.g. Pentium III)
- CPU supporting Enhanced 3D Now! (e.g. Athlon)
- CPU supporting 3D Now! (not much speed is expected for this)
- Multi-CPU (under Windows NT/2000/XP Pro)
- CPU supporting streaming SIMD Extensions 2 (e.g. Pentium4)
- DirectX 6 or higher
Zuletzt bearbeitet von Helmut am Feb. 21 2002,15:48 _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Marcus Else
Beitrag 3 - Verfasst am: Fr Feb 15, 2002 18:35 Titel: |
Der Unterschied zwischen der Plus und der normalen Version würde mich auch mal interessieren.
Beide kommen mit der gleichen Zahlenkombination (Build) daher. Das normale bei www.tmpgenc.net als Zip und die Plusversion von Pegasys als selbstentpackendes Exe.
Dafür ist tmpgenc.exe der normalen Version größer, und das trotz der Registrier- und Freischaltgeschichte.
Warum gibt es überhaupt diese 2 verschiedenen Versionen, denn das Download der Plusversion ist auch nur wie die normale Version in der Nutzungsdauer beschränkt, solange man nicht den Schlüssel erwirbt?
Hat das jemand schon mal gemacht? Wie sind die Erfahrungen?
Viele Grüße
von
Marcus |
MarkusSpurk
Anmeldungsdatum: 15.12.2001 Beiträge: 41 Wohnort: Saarland
Beitrag 4 - Verfasst am: Fr Feb 15, 2002 22:54 Titel: |
Ich habe die Plus-Version heute mittag per VISA-Card erworben, hat etwa 40 Minuten gedauert bis zur Übermittlung des Key :-).
Scheint auf meinem XP1800+ etwa 1/3 schneller zu laufen als die normale Version (war die 2.02 oder so), weiter hab ich noch nicht nachgeforscht, Bericht folgt.
Markus |
Svennek
Beitrag 5 - Verfasst am: Sa Feb 16, 2002 0:54 Titel: |
Bin kein CPU-Freak .. bezieht sich der Punkt "Athlon optmiert" auf alle Athlons oder nur die XPs oder auch die "alten" Athlon Thunderbirds? Weiß das jemand ?
Sven |
Beitrag 6 - Verfasst am: Sa Feb 16, 2002 2:06 Titel: |
Letzlich bedeutet die Optimierung ja wohl SSE und 3DNow optimiert.
SSE2 ist Pentium 4 only und wurde früher schon integriert.
Die Optimierung müsste daher für alle entsprechenden AMD-Prozessoren gelten, die 3DNow integriert haben (also auch dein Thunderbird ;)).
Und Athlon XP hat ja auch noch SSE drin ... |
thedigital
Beitrag 7 - Verfasst am: Sa Feb 16, 2002 9:33 Titel: |
Hm, ist auf jedenfall die erste Version, die bei mir unter WindowsXP abstürzt.
DV-AVI Typ 1 bleibt in der Batch-Verarbeitung am Beginn (vor erstem Frame) hängen. Prozess gekillt, kein Neustart, neuer Batch mit restlichen Jobs -> Null Probs. Lag wohl an der Uhrzeit (3:00am).
und tschüss,
Thorsten. |
Svennek
Beitrag 8 - Verfasst am: Sa Feb 16, 2002 9:34 Titel: |
Bedankt  |
