| Autor |
Nummer5
Anmeldungsdatum: 02.08.2002 Beiträge: 119 Wohnort: in Unterfanken
Beitrag 0 - Verfasst am: Do Apr 03, 2003 9:13 Titel: |
changelog ist noch nicht aktuell, habe aber das hier gefunden:
| Zitat: | Posted By: ejtagle
Date: 2003-03-22 01:56
Summary: New btwincap version coming soon...!
Under test it is a new btwincap version that fixes some issues found ... Better Pinnacle support, STB audio fixes, TV tuning speedups , more IR controllers supported (and , hopefully, some hardware bugfix workarounds)... It will be the 5.3.6 version... |
Download/News/Infos:
http://sourceforge.net/projects/btwincap/
http://btwincap.sourceforge.net/ _________________ so long Nummer5
Stolzer Besitzer einer Infinity SM Dolby Surround Boxenanlage ;) |
Cayne
Anmeldungsdatum: 26.03.2003 Beiträge: 2
Beitrag 1 - Verfasst am: Do Apr 03, 2003 14:57 Titel: |
Das ist der genaue changelog:
Fred Hoogduin sent code to implement a new Tuning algorithm. This was adopted as the new and only tuning algorithm. This will fix several problems, including some TV channels not properly tuned, channel number shifts, etc. It also speeds up the tuning process quite a bit.
There was a typo on the STB audio support that caused TV not to work properly on some of those cards. That is now fixed, so STB card support should work.
I added more IR receiver chips support. This could help to support the IR controller of your card.
Pinnacle card support was also improved. Newer Pinnacle cards should have their TV tuner modules properly autodetected.
Started to fix Dscaler field support. Seems to work sometimes. This still requires more investigation.
Oops! - Fixed (i hope) the last race condition that was causing systems to crash when the computer was loading the btwincap driver and the bt8x8 was sharing ints with some other active cards. Hope this will fix all startup/shutdown problems that were caused btwincap.
Weiss vielleicht einer, ob man mit dem Treiber in S3-Standby gehen kann und in den Ruhezustand?
Mit der letzten Version vorher ging das bei mir nicht... |
