Ossi
Anmeldungsdatum: 09.07.2002 Beiträge: 291 Wohnort: München
Beitrag 0 - Verfasst am: Sa Apr 05, 2003 12:06 Titel: |
Zitat: | HISTORY
2003-04-04 - VCDEasy v1.1.5
I made big developments efforts these last 2 months, I hope you will appreciate...
* Wanted by many many users since a long time... load/save projects !
* Ability to save and reuse the MPEG Analyze information (this will speed-up the reload of MPEG files, and so the reload of projects).
* Requested by a donor: Anti Flickering option added to the MPEG Stills page
* Picture viewer added to the MPEG Stills page (easier to understand the impact of each image transformation option)
* Mjpeg Tools v1.6.1 support added
* Use of the "CD Image File Recorder" concept
* Some compliance tests have been added.
* Requested by several donors: You can now work with network shares ("\\server\share\..." ).
* Again, in the spirit of making things easier to use, an expert mode have been added. The non-expert mode should be ok for most of the users. Some messages maybe be different and some options may be shown or not whether you are in expert mode or not.
* Project options have been reorganized on the Graphical Interface.
* Most of the settings not directly related to a VideoCD project have been moved to a settings dialog.
* In order to reduce the number of use troubles, and to reduce the complexity of the source code, I made a few changes:
- GNU VCDImager is no more an optional component.
- The location of the command line tools (GNU VCDImager, CDRDAO, MjpegTools) can no more be user defined.
- MPEG analysis is now mandatory for each MPEG file added to the project (I know it is not a good news for a few users, but it will reduce highly the number of troubles... [chapter entry points check, padding problems detection, making sure that no user will try to make chapters to a MPEG still,...]).
- No more "VCDEasy minimal distribution".
* Catalan Translation by Xavier (Thanks!)
* Traditional Chinese Translation by Koko (Thanks!) |
http://www.vcdeasy.org/modules.php?name=_Downloads |
