schon wieder neu ... TMPGEnc 2.56
Beitrag Beitrag 0 - Verfasst am: Mo Jun 24, 2002 8:33    Titel: Antworten mit Zitat
Version : 2.56. 2002/06/24
At project wizard, if source file is DV forma, always "bottom field first"is applied, and no field order detection is applied any more.
Supports reading more TGA formats : no compression 8/16/32bit, RLE compression 8/16/24/32bit (Previous version only supported "no compression 24bit".)
Bug fix : at AVI file output, sometime a frame was outputted as key frame despite it was not.
An AVI file which was outputted by TMPGEnc Plus was not sometime played in WMP properly with an error "Invalid file".
At AVI file out put, progress bar can be displayed properly even if interleave is "0".
www.tmpgenc.net
