Beitrag 0 - Verfasst am: Di Dez 09, 2003 10:08 Titel: DVD-Lab PRO 1.4 BETA 1 ist raus |
08.12.2003
Version PRO 1.4 BETA 1 (Download dvdlabup14beta1.exe (4MB), you need at least 1.3 full version)
From now DVD-lab versions will be splitted to Standard and PRO. This is important because there are too many advanced additions planned that a normal user may find them too overwhelming. The PRO version will require a bit more knowledge about the DVD authoring and structure but it will allow you to create DVD structure as you require. During the beta-testing DVD-lab registerd users will have no time limit on the PRO version.
Both Normal & Pro
- Component system in Connection windows - you can group objects and use them as black box, you can also export/import such components
- Adobe Photoshop 6,7 export/import fixes
- Load Sub Picture now converts the subpicture to 4 Colors
- You can directly drag images and *.mnu files from explorer to menu
- Output folder is now saved with the project.
- Testing mpa audio frequency in PS mpg without demuxing throw error if not 48kHz.
- You can also drag link from Project to Connections Menus and it will behave as if you use Draw Button Links. Bit awkward but the option is there.
- Some changes in mpa testing, the large allocated buffer seems to caused some problems
- Rebuild All Transitions on one click
- Add Transition Tool in connection (Draw arrow from menu to menu)
- Test compile now replaces also slideshow. The dummy image is now dynamically generated with information about the movie.
- Fix for the case when two or more menus with 16:9 motion background would crash compiler.
- Choose type of Default (Empty) project or create your own default project.
Pro Version
- Added real VMG Menus. Now you will be able to build the full DVD hierarchy.
- Import second VTS (menus+movie(s)) directly from any previously compiled project (loading the VTS_xx_0.IFO). This is a great new way to build multiple VTS DVD by simply first building one normal single VTS project, testing it, then use the compiled result directly as a second VTS in a new project. This way will add flexibility to the whole authoring process where you won't need to touch or recompile already working part.
- Re-authoring: Import VOB files (via IFO) as whole without joining - part of the multi-VTS solution as described above. It allows you to easy directly import previously created project or whole VTS created in other authoring software so you no longer need to join vobs and recreate chapter, etc, all is imported from ifo.
Mehr Info siehe bei mediachance
Anleitung für Erstellung von Multiple VTS, IFO import, re-authoring _________________ Gruß SVCDFan
Gotsche
Beitrag 1 - Verfasst am: Di Dez 09, 2003 11:25 Titel: |
Das klingt nach Abzocke!
Da muss man mal wieder draufzahlen, wenn man so ein simples Feature "Reauthoring ohne Joinen" verwenden möchte - was ist daran so pro, dass es mich überfordert??? Das Konkurrenzprodukt Tmpec Author kann das schon lange.
Mit den neuen Preisen von DVD-Lab 59->99 $ und nun eine Pro und eine Normalversion - der Programmierer möcht sich sicherlich schleunigst nen großen und schnellen Daimler Kaufen können!
Gotsche
michael_h
Anmeldungsdatum: 12.09.2003 Beiträge: 70
Beitrag 2 - Verfasst am: Di Dez 09, 2003 11:40 Titel: |
Deine Preisinfos sind aber nicht so ganz korrekt: 79US$ war Einstiegspreis, 99 US$ der offizielle Preis nach Betaphase. Ich würde nicht an die Decke gehen bevor es fertig ist. Vielleicht kommt´s nachher ganz anners... :-)
Michael |
MOIK
Anmeldungsdatum: 02.09.2003 Beiträge: 170
Beitrag 3 - Verfasst am: Di Dez 09, 2003 12:21 Titel: |
Die 79$ Einstiegspreis war dafür, dass wir noch Betatester spielen durften
Nun sieht es so aus, das man als registrierter Anwender die Betas frei benutzen kann.... und erst wenn das offizielle Release fertig ist, zur Kasse gebeten wird.... (wenn ich Oscar im Mediachance Forum richtig verstanden hab).
Ebenfalls weisst er darauf hin, das man für die Pro-Version schon mehr Ahnung von der DVD Erstellung haben sollte...
Zuletzt bearbeitet von MOIK _________________ Athlon 1600+, 756 MB RAM, 2x 60 GB Feste Platten, ED AVEasy, Pio 106, MSP 7, VDL 03/04, Studio 8, Procoder Express, DVD-Lab, Nero 5.5 |
Rainersurfer
Anmeldungsdatum: 26.01.2003 Beiträge: 36
Beitrag 4 - Verfasst am: Di Dez 09, 2003 12:29 Titel: |
Leider fehlt immer noch das angekündigte "multiple audio streams, subtitle editing"
Rainer |
Beitrag 5 - Verfasst am: Di Dez 09, 2003 12:30 Titel: |
Warten wir doch einfach ab, was sich da tut.
Ja, es dürfen diejenigen, die bereits die normale Version gekauft haben, die Betaversionen des PROs testen. _________________ Gruß SVCDFan |
Beitrag 6 - Verfasst am: Di Dez 09, 2003 12:32 Titel: |
Zitat: | Leider fehlt immer noch das angekündigte "multiple audio streams, subtitle editing"
Rainer |
Leute, was erwartet Ihr von einem Software-Entwickler?
Er hat doch gerade 1 Woche an der Trennung zwischen der Normal- und PRo-Version gearbeitet und legt damit den Grundstein für die Weiterentwicklung für die PRO-Version. _________________ Gruß SVCDFan |
Beitrag 7 - Verfasst am: Di Dez 09, 2003 12:35 Titel: |
Im Preis/Leistungsverhältnis liegt das Tool trotzdem noch gut im Rennen !
B.T.W.
Was ist denn aus Uleads angekündigter Version 2.0 von Powertools geworden ? _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Gotsche
Beitrag 8 - Verfasst am: Di Dez 09, 2003 13:48 Titel: |
Zitat: Ebenfalls weisst er darauf hin, das man für die Pro-Version schon mehr Ahnung von der DVD Erstellung haben sollte...
Ja, wenn ich nun keine Ahnung vom DVD-Authoring hätt, würd ich vielleicht erst gar nicht DVD-Lab verwenden!
Es gibt von der Bedienung her einfachere wenn auch im Funktionsumfang eingeschränktere Programme. |
wenzi
Beitrag 9 - Verfasst am: Di Dez 09, 2003 14:00 Titel: |
Oscar meinte auf meine Anfrage hin, dass die neuen Features wie z.B. Multi-Language und andere so nach und nach hinzukommen werden. Das hier ist der Grundstein für die Pro-Version, die später einmal weitaus mehr Features aufweisen wird. Features, die nicht jeder unbedingt benötigt. Daher auch die Aufspaltung in Pro und Standard. Was soll daran falsch sein? Muss er nun ein Leben lang für meine lumpigen 79 US$ für mich arbeiten und kostenlos weiter entwickeln?
Wer das erwartet, lebt in den Sternen: Bei Adobe Premiere oder MS Office sagt kein Schwein etwas, wenn alle 1-2 Jahre 300 Euros und mehr für'n Upgrade fällig werden. Auf diese Weise hat Billy the Kid bereits 2-stellige Milliardenbeträge gehortet... also bitte auf dem Boden bleiben. Zudem war diese Aufspaltung lange schon angekündigt. Kein Mensch muss da mitmachen.
MOIK
Beitrag 10 - Verfasst am: Di Dez 09, 2003 14:15 Titel: |
Für Otto Normalauthorer, welcher seine hausgemachte DV-Kost auf Silberscheiben verewigen will, wird die Normalversion ausreichen.... diejenigen, welche mehr verlangen, wird dann die ProVersion zur Verfügung stehen.
DVD-lab kann man auch ohne grosse Kenntnisse von DVDs verwenden.... ist ja im Prinzip wie ne Internetseite aufgebaut, da ein Button, dort ein Link.... da reicht auch die Schnellanleitung auf mediachance.com aus  _________________ Athlon 1600+, 756 MB RAM, 2x 60 GB Feste Platten, ED AVEasy, Pio 106, MSP 7, VDL 03/04, Studio 8, Procoder Express, DVD-Lab, Nero 5.5 |
Beitrag 11 - Verfasst am: Di Dez 09, 2003 14:48 Titel: |
Zitat: | der Programmierer möcht sich sicherlich schleunigst nen großen und schnellen Daimler Kaufen können! |
Hat er doch verdient, ok erstmal müssen sich dann Käufer für die Pro-Version finden
Rainersurfer
Beitrag 12 - Verfasst am: Di Dez 09, 2003 20:43 Titel: |
Zitat: | Leute, was erwartet Ihr von einem Software-Entwickler? |
Naja, wenn man in seinen Future Plan das angibt:
Zitat: | There are many future plans for enhancements: multiple audio streams, subtitle editing and multi-angles. |
dann kann das schon sein, daß man das erwartet und nicht eine plötzliche(?) Aufplittung in Standard und Light-Version mit ganz anderen Features, die ich persönlich noch nicht vermisst habe. Für Subtitle, wenns denn mal kommen sollte, braucht man bestimmt die Pro-Version.
Bei Premiere und Co weiß man´s aber schon ein halbes Jahr vorher was kommt und nicht just an dem Tag, an dem man die Registrierung erhält.
Rainer
Wolfgang
Beitrag 13 - Verfasst am: Di Dez 09, 2003 22:26 Titel: |
Zitat: | Bei Adobe Premiere oder MS Office sagt kein Schwein etwas, wenn alle 1-2 Jahre 300 Euros und mehr für'n Upgrade fällig werden. Auf diese Weise hat Billy the Kid bereits 2-stellige Milliardenbeträge gehortet... |
Und jetzt will Oscar das auch??
Ich will erst mal das tool haben, für meine 59 Teuronen in der Sammelbestellung - na wenn ich vorher gewußt hätte, das Oscar Billy ist!!
 _________________ Gruß,
Wolfgang
http://videotreffpunkt.com |
Beitrag 14 - Verfasst am: Mi Dez 10, 2003 1:20 Titel: |
Zitat: | Oscar meinte auf meine Anfrage hin, dass die neuen Features wie z.B. Multi-Language und andere so nach und nach hinzukommen werden. |
weisst dun näheres dazu? Könnte ich endlich Griechisch benutzen? _________________ Sotiris
Beitrag 15 - Verfasst am: Mi Dez 10, 2003 9:19 Titel: |
Zitat: | Zitat: | Leute, was erwartet Ihr von einem Software-Entwickler? |
Wie schon gesagt, aber nicht nach 1 Woche.
Ihr müßt halt daran gewöhnen, daß Oscar nach und nach die Feature implementiert und diese Betas zum Testen zur Verfügung stellt. Ansonsten warte einfach mal 1 oder 2 Monate ab und schaue dann nach, wie weit er ist. _________________ Gruß SVCDFan |
wenzi
Beitrag 16 - Verfasst am: Mi Dez 10, 2003 12:52 Titel: |
Zitat: | weisst dun näheres dazu? Könnte ich endlich Griechisch benutzen? |
Habe mich vielleicht falsch ausgedrückt: Ich meinte mehrere Audiokanäle (Sprachversionen)! Was die Bedienungssprache angeht, so will er evtl. Japanisch einbauen. Nützt uns aber nicht viel... _________________ Viele Grüße, Wenzi |
Beitrag 17 - Verfasst am: Mi Dez 10, 2003 13:47 Titel: |
Zur Info:
Ich habe eingangs im ersten Posting einen Link zu "Anleitung für Erstellung von Multiple VTS, IFO import, re-authoring " hinzugefügt. _________________ Gruß SVCDFan |
kempfand
Anmeldungsdatum: 26.10.2001 Beiträge: 157
Beitrag 18 - Verfasst am: Do Dez 11, 2003 5:36 Titel: |
| Von Ulead's Seite:
Zitat: | DVD Workshop 2 will be available in January for $495 via video resellers and www.ulead.com |
sowie
See the Full Features (PDF, 106KB)
Sowie:
Grüsse,
Andreas |
wenzi
Beitrag 19 - Verfasst am: Do Dez 11, 2003 11:47 Titel: |
495 Dollar? Völlig uninteressant zu diesem Preis, was den Hobbyanwender betrifft. Sind wohl größenwahnsinnig geworden... _________________ Viele Grüße, Wenzi |
