DVB-lab Pro Beta Two
Svenni
Anmeldungsdatum: 06.04.2002
Beitrag Beitrag 0 - Verfasst am: Mo Apr 19, 2004 2:09    Titel: DVB-lab Pro Beta Two Antworten mit Zitat
Na, da bin ich mal gespannt, was das Bugfixing und die Kompatibilität betrifft:
Bugfixes:
- Fixes in the beta 2 from beta 1:
- Muxer problem during placing navigational parameters
- Messed FP, VMG->Movie links if movies are added zig-zag to various VTS's
- Test Compile shown wrong images in multi VTS
- Render motion Pre-buffering bug (workaround...it is some MS compiller error)
- Scene Selection menus works only for VTS1
- Audio in slideshow can't be shorter than slide time
- Audio slideshow can't be longer than 151 sec
- Muxer elementary shows "End" and then exits
- Wrongly calculated sectors if no VMG present (GetVTS sectors in Ifoedit will correctly uncover this)
- Remote menu button not saved
- CallSS VMGM pgcn resume_cell 0 => 1
- Muxer crashes during compiling due high bitrate peak
- VTS are not enterred in VMG_VTS_ATTR
- subtitle not working for PAL
Added:
- Added Condition Splitter object, splits the link to two objects depending on the condition (Globar Parameters GPRM)
- Added a table view in connections - it can shows items in a table where you can also change end links etc..
- Added Audio-Only Title. This is a "Movie" with only audio track, not video, optionally you can add a title screen to it (such as name of the song....) that will be displayed during the audio playback. You can also set "chapters", here called Marks and have multiple audio there.
- Ability to override the Global settings for each VTS - each VTS can have different aspect for menus and also different system.
- VM commands shows also default inserted DVD-lab commands
- Right click on Properties first select the item and vts then shows the menu
- Quick VTS select button in connection link bar that shows which VTS is currently selected, Also a bit tighter connection between the Project tree control and Connection window.
- Added Film Strip wizard (much like scene selection wizard)
- Added Region checking smart component
Quelle
jemue
Anmeldungsdatum: 03.12.2002
Beitrag Beitrag 1 - Verfasst am: Mo Mai 24, 2004 7:44    Titel: Antworten mit Zitat
Irgendwie haben wir was versäumt.
Es ist schon die Pro-Beta3 erschienen.
Fixes in the beta 3 from beta 2:
-Language combos shows more items than there are languages
-Some pulldown videos don't create chapters
-Transitions had swapped blue and red color
-SetHL-button 0 not allowed on Microsoft based software players
-Multiplexer, playback of pulldown files
-Chapters are wrong on pulldown files
-Audio on complex menu will not compile (but compiles on simple menus)
-More than 1 audio title will crash compiler.
-Highliting trouble on some pal players with motion menu
-DTS not all bitrates works correctly
-Sync issues with subtitles DF/NDF see bellow
Additions, changes
-The previous Play list is now renamed VTS Play list and doesn't allow bridge anymore (may be later completelly removed for redundancy)
-Added Play list that can address any movie from any VTS without a need for bridge
-Zoom out in Connections
-VTS Import is back, now you can import up to 3 external VTS's
-Added Non-Drop Frame and Drop Frame in subtitles dialog to "fix" the sync problem
-Sort assets by name or by type
-Add/Remove object to/from component
Gruß jemue
Beitrag Beitrag 2 - Verfasst am: So Jun 06, 2004 11:06    Titel: Antworten mit Zitat
Seit dem 1. Juni gibt's die Beta 4 Pro:
Fixes in the beta 4 from beta 3:
* audio title not working properly (same audio plays on multiple titles, problem with large lpcm files)
* no warning if user doesn't use same number of subtitles in all movies in one VTS, solved by adding dummy subtitles
* motion menus on PAL/NTSC still not working correctly - highliting shows for brief time then dissapear which disallow for navigation from the menu
* Adding Audio/Subtitle/Resume Stream selection to a VMG menu button will crash (typo error)
* The Import VTS appears to allow to edit VM commands - but it shouldn't
* On VMG menu buttons it appears as if you can link to any chapters of any movie, but that's wrong. From VMG you can connect only to movie start. Only a VTS menu can have access to chapters.
* Sometimes when you scroll in movie and then add chapter it adds the chapter a bit later
* remote menu button link should not be able to set for script objects
* empty branch object will mess up compilation.
* PAL motion menu renders with 29.97 fps
* VM editor allows adding invalid condition Type 3 comparing SPRM and constant: if (SPRM8 == num) etc. (SPRM can't be on left side, neither it can be compared with constant)
Not yet addressed known bugs:
* on 16:9 all subtitles are set to play first subtitle stream
Additional features
* added *.SSA and *.SON subtitle import.
* Edit VM command in Menu Buttons
* Snap to Grid in Connection window
* Create Image file during compile
* Create DVD-9 image files during compile with automatic layer break
ThomasS
Beitrag Beitrag 3 - Verfasst am: Mi Jul 14, 2004 8:58    Titel: Antworten mit Zitat
... und schon wieder eine:
Die Unterstützung vom ShuttlePro hört sich nett an.
PRO Beta Five C (DVDlabProB5c.exe 5.5MB)
Jun 23nd, 2004
A quick release from Beta 5a and beta 5b.
Fix for unexpected crashing
Subtitles are back
PRO Beta Five
Jun 22nd, 2004
Installation: DO NOT install over previous DVD-lab standard version. Install in separate directory. You will be able to run it fine, but there will be missing backgrounds, objects, transitions and styles. You can copy these folders from DVD-lab installation. When windows asks you during copying such message : "This Folder already contains a folder named Objects", click YES.
Fixes in the beta 5 from beta 4:
16:9 allows only one subtitle (ID problem in IFO), same as in beta 3
Build image from compile window use default string for Volume Name
16:9 menus can be viewed only on wide screen, on 4:3 screens the menu is non-functional
too long or too many audio titles will eventually crash compiller (VOBU count)
import VTS doesn't write correct number of VTS in VMGM_MAT and VMG_VTS_ATRT
VM Commands inconsistently shows decimal and hexadecimal numbers wherewer it likes (should use only decimal by popular vote).
If user press Cancel on Button VM command, last command is not returned.
Additional features and improvements
fully working multi-aspect 16:9 menus. Now widescreen menus works on 4:3 as well. New settings in properties to separately select the display mode (LB or PS) for widescreen menus on 4:3
slide duration extended to 1800 seconds
memory increased to handle larger GOP sizes for TiVO and DVB streams
Decoder buffer size checking
new Panorama menu.
See and add VM commands for shadow VTS root
See and add VM commands for Title Button
See and add VM commands for First Play
Connection window can be split to two independent rows, each displaying different part of the workplace (each with different settings)
Direct Compile tool. Enables you to load last compile, change just few things (for example video files) and then compile again without going to interface. Good for repeating simillar projects that always needs to change only few things.
Return to last menu object. Linking a movie to it will return to the last viewed menu in this VTS or VMG menu.
Case List. Depending on the value of GPRM it can link to various movies, menus, VMG menus or objects
Support for ShuttlePRO2 and ShuttleXpress controllers (I will later publish the key settings)
Viele Grüße von ThomasS
robert980
Anmeldungsdatum: 09.09.2002
Beitrag Beitrag 4 - Verfasst am: So Jul 25, 2004 23:46    Titel: beta6 Antworten mit Zitat
Ahhhhh,
Beta6 ist draussen, changelog kann ich leider nicht anbieten, da die Seite heute wohl offline ist, aber ich habe eine Frage:
Wie kann man das relaxed multiplexing, daß leider ab beta2 komplett deaktiviert ist (nicht nur nicht auswählbar - es ist nirgends genannt) dennoch nutzen?
Ich hatte immer das Problem, daß beim Main-Multipl.-Modus ab und an frames im Film fehlten;
nachden ich das hier im Board vor langem mal gepostet hatte, wurde mir weitergeholfen mit dem Argument, daß das bekannt sei und daher die altern. multiplexing engine zu verwenden sei und Tatsache damit hatte ich dann niemehr Probleme. (Alles noch zu Version 1.3 Zeiten).
Ich werds halt jetzt mal mit der main probieren, da mir mit der 1.4b3 ja nix anderes übrig bleibt, vielleicht wurde der FEhler ja inzwischen behoben. Warum ich überhaupt die beta verwende? >> Multiple VTS
Die beta6 möchte ich (noch) nicht benutzen, da da doch noch einiges hinzugekommen ist und ich bezweifle da durchzublicken.
Gruß und danke
rob
simbae
Anmeldungsdatum: 04.04.2002
Beitrag Beitrag 5 - Verfasst am: Mi Aug 04, 2004 20:20    Titel: Antworten mit Zitat
PRO Beta Seven
August 4th, 2004
Fixes from beta 6
- transitions for widescreen menus don't work correctly (always 4:3)
- movie without vts menu still CALLSS Root Menu in POST
- zoom out + F2 is messy
- force activate button should not be used if cell 3 in delayed menu exist
Added
- Intro Effect in Render Motion - create intro+motion that can be later used in delayed buttons menu.
- delayed menu cell 2 can loop or continue depending if the end link exist.
- objects in menu are now bit "sticky" when you click on them which prevents from accidental moving it.
- added delayed buttons feature to VMG
- if you use mpg file with AC3 stream or use mpg/vob and add more audio or subs the compile will first offer to demultiplex these files in order to be able to successfuly continue.
- if mpeg file has already PCI and DSI packets, it is then used as VOB during compile (to solve the audio problem on "DVD-ready" mpegs without demuxing)
Is lt. Oscar wohl die letzte Beta vor dem Release.
simbae
Beitrag Beitrag 6 - Verfasst am: Do Aug 12, 2004 16:01    Titel: DVD Lab Pro Beta 8 Antworten mit Zitat
Die Zyklen werden kürzer und kürzer ...
PRO Beta Eight
August 11th, 2004
Fixes from beta 7
- subtitle language show always English when loading project
- demux can't open the file if it is already open in preview
- DTS in WAV is now recognized
- Memory requrements trimmed down (about 2.5 x times) from beta 7. As a result of this only first 50 menus in each VTS are allowed to have delayed menu buttons (cells) for motion menu
- zoom in menu changed by mouse wheel has not been remembered
- Motion menu ES/PS is recognized by extension only, should test if *.mpg may be perhaps ES
- Some muxer crash on DVB files with >50 frames in GOP
Added:
- Menu objects now can have a bitmap fill with various effects for metal etc..
- 2-New bevels in Effect - a realistic Metal Bevel and Plastic Bevel
- Some of the bevels and glass effects had been renamed and also the order changed, this may affect loading of some old project (a different effect will be used than previously choosen)
- Check for overlapping subtitles and End<Start
- Added offset tool to subtitles, allows also progressive offset
- Ability to create DVD without Abstraction Layer for low-level authoring. DVD-lab will not insert any of its abstraction commands and you have to support DVD playability only with VM Commands.
- duration of slide is now from 1 - 3600 sec., slides have automatically set UOPS for FW/BW (in slideshow you suppose to use Next and Previous)
